M13a engine valve shim tool
- skywalker65
Topic Author
- Premium Member
- Thank you received: 20
31 Mar 2016 06:01 #164678
by skywalker65
If in doubt ...... Flat out ??
M13a engine valve shim tool was created by skywalker65
Ey up all,
Fancy getting the valve adjustment shim tool for my toolkit just in case lol. Anyone got one for sale or know of an alternative other than Suzuki ?
Anyone know the part number of the tool and a rough cost?
Ta
Ta
31 Mar 2016 06:59 #164681
by facade
Replied by facade on topic M13a engine valve shim tool
There are 3 different claw like brackets that screw on the cam carriers and push the buckets down.
If I ever get a round tuit (my nan had one on top of her fireplace) I thought I'd just struggle or cobble something up.
AFAIK, there are no after market ones, as no-one ever messes with them.
(bad really, I'd expect the gaps to close up as the valves wear into the seats on Tesco petrol, but it needs an expensive gasket and seals just to look at them)
31 Mar 2016 07:30 #164685
Replied by mlines on topic M13a engine valve shim tool
Genuine Suzuki tool 09916-67021 - £101
Shims 12892-69G10-XXX - £6.70 each
The following user(s) said Thank You: skywalker65
31 Mar 2016 07:53 #164686
I'd leave that until the just in case bit is needed :blink: :laugh: :laugh:
Replied by Daniel30 on topic M13a engine valve shim tool
skywalker65 wrote: Ey up all,
Ta
31 Mar 2016 21:16 #164717
by kirkynut
Replied by kirkynut on topic M13a engine valve shim tool
The trouble with shimming an engine with bucket shims is that you can measure what size you need but when you fit the shim find it's not right despite your measurements.
So you bought the wrong shim and are left in a pickle. With 16 valves you can be in 16 pickles!
- yira
12 Jul 2021 02:12 - 12 Jul 2021 02:12 #236604
by yira
Replied by yira on topic M13a engine valve shim tool
This may be a viable substitute to hold the spring bucket down. £12 is more tolerable for such a simple tool
www.amazon.com/Motion-Pro-08-0017-Suzuki-Yamaha/dp/B000UKIN8Q
Last edit: 12 Jul 2021 02:12 by yira.
Time to create page: 0.186 seconds
