Noisy water pump
30 Mar 2016 13:26 #164643 by Mike G
Noisy water pump was created by Mike G
Got an annoying noise coming from the engine. Think it's coming from the water pump. It does change frequency when the engine revs get higher (didn't rev it in the video tho). I think it could be the pump bearing(?) It's not causing any problems so far, but just wondered in case I'm wrong as to what the noise could be?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
30 Mar 2016 13:35 #164645 by Mike G
Replied by Mike G on topic Noisy water pump
couldn't embed the video for some reason. But here it is.
30 Mar 2016 14:52 #164646 by j999pre
Replied by j999pre on topic Noisy water pump
Try removing one belt and see if the noise goes at least then you can rule some things in and some out
Grey pick up Jimny
  • NicBeeee
30 Mar 2016 14:53 - 30 Mar 2016 14:54 #164647 by NicBeeee
Replied by NicBeeee on topic Noisy water pump
Perhaps try removing the fan belt and running for a few seconds to eliminate, plus you will be able to spin the water pump by hand to get a feel for it.
\beat me to it :blush:
Last edit: 30 Mar 2016 14:54 by NicBeeee.
30 Mar 2016 15:06 #164648 by Mike G
Hi Gents,
Thanks for the responses. I had a look on youtube and seen someone spraying water on the inside of the belt to eliminate belt squeal from the fault diagnosis. It's definitely not the belt as the squeal is still present after a quick spray (saved me taking the belt off) Last time I changed the belt was fairly recent and I checked all the pulleys for play when the belt was removed, they seemed fine. Things could have changed from that time of course. I can live with the squeal for now, but my main concern was whether the water pump would fail as the sound seems to be coming from that vicinity.
Looks like I'm going to have to take the belt off again to confirm things. Just glad the weather is more agreeable.
30 Mar 2016 16:14 #164651 by facade
Replied by facade on topic Noisy water pump
Look down at the crank pulley when the noise is present and see if it is vibrating :ohmy:
Time to create page: 0.160 seconds
