x eng handbrake
- rexthecat
20 Mar 2016 20:57 #164123
by rexthecat
x eng handbrake was created by rexthecat
Has anyone fitted an x eng to a jimny? I had one fitted but can't get it to hold. Problem seems to be the lever that pushes the plate at the back isn't exerting enough force to lock the wheels. If I tighten the slider bolts so the pads are closer it holds better....BUT they rub and heat up the disc. At the moment the cable is sort of mounted at right angles to the plate. Looks like on the X eng site the cables straight to the lever. I can see why they did it that way but just doesn't seem to work so well.
Has anyone got pics of how they set it up?
Cheers
Cheers
- Smoggy
20 Mar 2016 21:59 #164129
by Smoggy
Replied by Smoggy on topic x eng handbrake
I had one Rex and no matter how I tried to set it up I still had the problems you have.
21 Mar 2016 07:06 #164139
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic x eng handbrake
I've got one fitted, I have actually welded it to my RS bucket. I can get some pictures of it fitted but probably not until Friday.
- rexthecat
21 Mar 2016 22:41 #164180
by rexthecat
Replied by rexthecat on topic x eng handbrake
Bugger thats not the answer I was hoping for .....what did you use instead Smoggy? Cheers Jezz pics would be great. The callipers I've got on the back are front ones of a Vitara so no cable attachments. Saw Jimnybits have conversion using Renault callipers but not in stock unfortunately.
22 Mar 2016 06:44 #164183
by Jezz
I have to say mine works perfect, A bit fiddly to get it right but holds the jimny fine.
Time to create page: 0.096 seconds
