4wd not working
- Fs69
18 Mar 2016 07:09 #163930
by Fs69
4wd not working was created by Fs69
Hi all,
Another problem I only realised last night that I've recently done a kingpin bearing change, checking the Jimny over last night and noticed the 4wd light is not coming on when engaging the 4wd, I didn't have time to check anything else then last night but any advice on this would be appreciated very much
Cheers all
Cheers all
18 Mar 2016 08:49 #163933
by Busta
Replied by Busta on topic 4wd not working
There is lots written on here about the simple things to check and there is a useful guide under the information tab at the top of the page. If it worked before you did the kingpins, it will most likely be something simple like a hose damaged or the hub not sealing.
- Fs69
18 Mar 2016 14:58 #163964
by Fs69
Replied by Fs69 on topic 4wd not working
Had another look at this, can't find any obvious leaks in the pipes, but if I select 4wdh then 4wdl the light illuminates but flashes, select 4wdh and it stays illuminated but remains flashing, any ideas and is there a reliable way to check the pipes.
Thanks
Thanks
19 Mar 2016 04:38 #164009
by kirkynut
Replied by kirkynut on topic 4wd not working
Now you get some people who say that the auto hubs are great. I'm not one of them and for this reason I wrote this :
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=55862
You make your choice as to whether you find the fault or go fixed/manual hubs.
- Fs69
20 Mar 2016 16:26 #164110
by Fs69
Just an update, I can hear the hubs engaging when I select 4wd and then disengaging when I deselect 4wd drive, any ideas?
20 Mar 2016 19:34 #164117
by Busta
If the hubs are engaging 4wd is working. It's probably a slight leak somewhere.
Time to create page: 0.095 seconds
