Alternator voltage drops gradually
  • GuardianAngel
17 Mar 2016 18:26 #163901 by GuardianAngel
Alternator voltage drops gradually was created by GuardianAngel
A few weeks ago I noticed that the battery was not charging properly, and after testing the output from the alternator, it was about 11.5 volts so replaced the alternator with a second hand one. I tested the voltage and it was around 14.5 at idle, but after taking it for a test run the battery was flat. So there is me thinking I needed a new battery. But the battery is only a couple of years old. I also checked all the earth points under the engine bay and cleaned them just incase I had a bad earth and they all looked good, tight and clean.
Anyway tonight I went out and tested the voltage off the new (second hand) alternator and it started at 14.5 volts, but as the engine warmed up the voltage output slowly kept dropping until it steadied around 11.5 volts. By this time the battery was flat. I tested the alternator voltage at the battery as well as at the alternator as well.
So, any ideas as to why this could be the case? Could I just be unlucky with the second hand alternator I have fitted as having the same problem as the one it replaced? Is there anyway this could just be the battery that has had it (seems unlikely if the alternator is not pushing out the right voltage)?
It is an M13A engine BTW with no second battery or split charging circuit added, it's all standard.
Cheers
  • OllieNZ
17 Mar 2016 18:45 #163905 by OllieNZ
Replied by OllieNZ on topic Re:Alternator voltage drops gradually
Can you substitute the battery? A damaged cell could potentially cause a similar issue. Did you try it at idle or with some revs?
17 Mar 2016 21:04 #163914 by kirkynut
Perhaps the old alternator did not do the battery any good and it's had it.
The following user(s) said Thank You: GuardianAngel
  • GuardianAngel
17 Mar 2016 21:12 #163915 by GuardianAngel
Replied by GuardianAngel on topic Re:Alternator voltage drops gradually
I dont have a spare Jimny sized battery, so I might just bite the bullet and get one and see. Out of interest, is it possible to fit a higher output alternator like off a Vitara or something?
Sent from my SM-T705 using Tapatalk
20 Mar 2016 08:41 #164092 by skywalker65
Might be able to shed some light on this for you as I've just done an absolute pig of a charging fault on one of our bikes with the same symptoms. Would charge ok when cold but when it warmed up it stopped charging.
Alternator function was ok thank god cos it's an engine out on one of these to replace it. As was the regulator / rectifier
Turned out 1 of the 2 wires from the output side of the regulator / rectifier was the culprit namely the earth wire. The resistance of the wire was altering due to the amount of current. You could measure the voltage and watch it steadily drop at the battery.
So I'd be looking at the wiring output from your alternator or main earths and see if the resistance alters from when it's cold / hot
If in doubt ...... Flat out ??
  • helijohn
20 Mar 2016 08:53 #164095 by helijohn
Replied by helijohn on topic Alternator voltage drops gradually
skywalker65 wrote: Might be able to shed some light on this for you as I've just done an absolute pig of a charging fault on one of our bikes with the same symptoms. Would charge ok when cold but when it warmed up it stopped charging.
That is very useful as I too have a similar problem.
How quickly should the charging system get a battery charged assuming a battery just about turns the engine over when it is a cold start?
Time to create page: 0.182 seconds
