Alternator voltage drops gradually
- GuardianAngel
Anyway tonight I went out and tested the voltage off the new (second hand) alternator and it started at 14.5 volts, but as the engine warmed up the voltage output slowly kept dropping until it steadied around 11.5 volts. By this time the battery was flat. I tested the alternator voltage at the battery as well as at the alternator as well.
So, any ideas as to why this could be the case? Could I just be unlucky with the second hand alternator I have fitted as having the same problem as the one it replaced? Is there anyway this could just be the battery that has had it (seems unlikely if the alternator is not pushing out the right voltage)?
It is an M13A engine BTW with no second battery or split charging circuit added, it's all standard.
Cheers
- OllieNZ
- GuardianAngel
Sent from my SM-T705 using Tapatalk
- skywalker65
- Premium Member
- Thank you received: 20
Alternator function was ok thank god cos it's an engine out on one of these to replace it. As was the regulator / rectifier
Turned out 1 of the 2 wires from the output side of the regulator / rectifier was the culprit namely the earth wire. The resistance of the wire was altering due to the amount of current. You could measure the voltage and watch it steadily drop at the battery.
So I'd be looking at the wiring output from your alternator or main earths and see if the resistance alters from when it's cold / hot
If in doubt ...... Flat out ??
That is very useful as I too have a similar problem.skywalker65 wrote: Might be able to shed some light on this for you as I've just done an absolute pig of a charging fault on one of our bikes with the same symptoms. Would charge ok when cold but when it warmed up it stopped charging.
How quickly should the charging system get a battery charged assuming a battery just about turns the engine over when it is a cold start?
