Grumpy Steering
09 Mar 2016 09:52 - 09 Mar 2016 09:53 #163530
Grumpy Steering was created by Daniel30
I have a new noise coming from my steering any ideas king pin and bearing test done and ok and no leak on the swivel joint thingy :blink: not a great clip but you can feel it when cornering something clunckin and moving about panhard rids and bushes are new......... cheers
Last edit: 09 Mar 2016 09:53 by Daniel30. Reason: Delete
09 Mar 2016 09:55 #163531
Replied by Daniel30 on topic Grumpy Steering
10 Mar 2016 19:10 #163583
That's that then :blink:
10 Mar 2016 20:07 #163589
by Halford
Replied by Halford on topic Grumpy Steering
:huh:
I'd jack it up and pop in on axle stands, then move the wheels whilst at ground level to try and locate the source of the noise
Maybe pop your phone underneath to film and record sound whilst you turn the steering ?
These 2007 trucks are dropping to bits
10 Mar 2016 20:27 #163591
Thanks Halford I will try jacking it up and have anther listen
Yeah tell me about it try to get it how I want it to look and it starts falling apart :laugh:
13 Mar 2016 06:46 #163677
by kirkynut
Replied by kirkynut on topic Grumpy Steering
I think you'll have to work through the steering methodically with an assistant turning the steering wheel for you.
Start at the uj on the steering from the column which is under the bonnet. Hold the shaft to feel for movement in it.
Then work down and make sure all bolts are tight on radius arms and Panhard Rod.
Time to create page: 0.092 seconds
