Grumpy Steering
  • Daniel30
10 years 8 months ago - 10 years 8 months ago #163530 by Daniel30
Grumpy Steering was created by Daniel30
I have a new noise coming from my steering any ideas king pin and bearing test done and ok and no leak on the swivel joint thingy :blink: not a great clip but you can feel it when cornering something clunckin and moving about panhard rids and bushes are new......... cheers
Last edit: 10 years 8 months ago by Daniel30. Reason: Delete
  • Daniel30
10 years 8 months ago #163531 by Daniel30
Replied by Daniel30 on topic Grumpy Steering
  • Daniel30
10 years 8 months ago #163583 by Daniel30
That's that then :blink:
10 years 8 months ago #163589 by Halford
Replied by Halford on topic Grumpy Steering
:huh:
I'd jack it up and pop in on axle stands, then move the wheels whilst at ground level to try and locate the source of the noise
Maybe pop your phone underneath to film and record sound whilst you turn the steering ?
These 2007 trucks are dropping to bits
  • Daniel30
10 years 8 months ago #163591 by Daniel30
Thanks Halford I will try jacking it up and have anther listen
Yeah tell me about it try to get it how I want it to look and it starts falling apart :laugh:
10 years 8 months ago #163677 by kirkynut
Replied by kirkynut on topic Grumpy Steering
I think you'll have to work through the steering methodically with an assistant turning the steering wheel for you.
Start at the uj on the steering from the column which is under the bonnet. Hold the shaft to feel for movement in it.
Then work down and make sure all bolts are tight on radius arms and Panhard Rod.
Time to create page: 0.094 seconds
