Vacum Hub/System issue
- phippj1
10 years 8 months ago #163503
by phippj1
Vacum Hub/System issue was created by phippj1
Hi All,
Hoping for some help and guidance.
My brothers Jimny is having 4 wheel drive issues. If you put her in 4whl drive high the light does not come on at all, put the box into low and the light does still not come on till you drive it and then it flashs. Thought it would be the four wheel drive switch on the back of the transmission, but have checked this as per the instructions the the "how to guide on here" and the switch is working fine. Checked all the piped and there are no obvious splits etc. I then jacked up the car and to my surprise both front hubs are locked on permanently.
So four wheel drive is working but not as it should be. My brother would prefer not to fit locking hubs as he likes the convinience of the vacum hubs. Any ideas on where I should go with the system now?
I really hoped I was going to find the switch broken but its never that simple.
Thanks for in advance
- mickt
10 years 8 months ago #163516
by mickt
Replied by mickt on topic Vacum Hub/System issue
Which model is it i.e. what year and engine. Then try the search option at the top of this page and type in 4wd failure and work your way through to see if you can spot anything that points you in the right direction.
10 years 8 months ago #163521
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Vacum Hub/System issue
Sometimes it takes a while for the light to come on, as if there is s vacuum leak it will take a while for the light to come on flashing.
Grey pick up Jimny
Time to create page: 0.087 seconds
