Checked the basics and still got half the problem
  • JimnyGirl85
07 Mar 2016 21:01 - 07 Mar 2016 21:02 #163471 by JimnyGirl85
Hi, I'm new to the forum.
I invested in my '99 Jimny V reg 7 years ago and even through its years of neglect while I was at uni it has powered on through. I have, since qualifying, got up to date on all maintenance. In August 2013 it had a clutch professionally fitted. Months later I needed the 4wd and noticed that the light constantly flashed but everything engaged and worked as it should.
On Friday we got a dump of snow and for the first time ever my beautiful little car failed, the 4wd just didn't engage.
My partner has repaired the obvious which was a split pipe which had come loose. He's driven it since and said he is confident the 4wd is now functioning, but the light still flashes!
Both myself and my partner (self confessed petrol head) have read all the light flashing posts on here and none seem to match our situation.... Any ideas before I hand it to the mechanic for 'investigation' and it costs a small fortune?
FYI I have already welded it back together and parts wise it's like triggers brush so I don't mind doing work on it, it's done 145,000 and I've had multiple, independent mechanics say the engine sounds sweet as a nut.
Thank you :)
Last edit: 07 Mar 2016 21:02 by JimnyGirl85.
  • minibbb
07 Mar 2016 21:23 #163473 by minibbb
I can't help with the flashing light situation however I would strongly suggest you for manual hubs.
The vacuum hubs can be a Royal pain in the bum and the manual ones take all the worry about about them not working when you need them :)
07 Mar 2016 21:51 #163474 by Keithy
Do you get 2 clicks in quick succession when you engage 4wd?
And another 2 when you disengage?
If the clicks are slow you have vacuum being lost..
Try the diagnostics info on here....enough can be gleaned to get the gist.
Check the seals on the inside of the front hubs if the pipework is good.....if the seals are worn out change em.......they'll still be worn out if you give in fixing the vac hubs and fit muddy boot ones.
For reference mine take around a quarter second to engage/disengage.
Welcome to the forum!
The following user(s) said Thank You: JimnyGirl85
08 Mar 2016 05:16 #163482 by Lambert
Another vote for manual hubs. Get the avm hubs from jimnybits they bolt straight on no fuss then just seal off the vacuum pipes in both directions in the engine bay to keep crud out of the hubs and to make the solenoids and computer happy and bingo 4x4 on demand and no flashing lights.
08 Mar 2016 08:22 #163486 by Busta
No need for vacuum hubs if the 4wd is working! The flashing light will most probably be because there is still a slight vacuum leak. Not enough to stop the hubs engaging, but just enough for the system to think they haven't. Check your wheel bearings if you haven't already. Play in the bearing means the hubs don't seal properly. Otherwise, it's a case of checking further along the lines for leaks.
  • JimnyGirl85
08 Mar 2016 19:27 - 08 Mar 2016 19:32 #163512 by JimnyGirl85
Replied by JimnyGirl85 on topic Checked the basics and still got half the problem
Thanks, where do I find said diagnostics bit? :)
Will get my man to investigate the wheel calipers, I definitely get 2 quick positive clicks on dropping into 4wdh.
As simple a life as manual hubs sound they can provide my 4wd is for snow and getting off muddy fields, is it not a bit tedious having to get in and out all the time?
Anyway I'm a girl, and even horsey girls have a limit to how dirty their hands get :P
Last edit: 08 Mar 2016 19:32 by JimnyGirl85.
Time to create page: 0.105 seconds
