LOWERING a Jimny?
- S200KYS
03 Mar 2016 12:12 - 03 Mar 2016 12:18 #163284
by S200KYS
LOWERING a Jimny? was created by S200KYS
I know, it's a daft question for anyone to ask, especially me, and yes, I have searched and read every previous thread on lowering before someone
flames me!... :laugh:
A local old fella came to see me yesterday in his 12 plate Jimny, he says his Jimny is "unstable in the wind and/or at speed", at 90mph indeed... LOL :woohoo:
I did try explaining to him that it's a little 4x4 with a higher centre of gravity than a normal car (He had a Subaru Imprezza before the Jimny) and quite narrow as well... And does require a slightly different driving style even in a standard one... I did show him mine too! :blink:
He's already widened the track with wheel spacers, but he seriously wants to LOWER it a bit, just an inch or two...
So...
Does anyone know of anyone that supplies Jimny LOWERING springs, or has seen anyone on the internet that has LOWERED their Jimny using springs off a different vehicle?...
Thanks in advance...
Dave
So...
Dave
Last edit: 03 Mar 2016 12:18 by S200KYS.
- ewanm77
03 Mar 2016 13:48 - 03 Mar 2016 13:56 #163286
by ewanm77
Replied by ewanm77 on topic LOWERING a Jimny?
if vitara springs fit you can get -50mm
Last edit: 03 Mar 2016 13:56 by ewanm77.
03 Mar 2016 14:39 #163289
Replied by mlines on topic LOWERING a Jimny?
Did you mention correct tyre pressures and he might find a steering damper helps as well.
- gilburton
03 Mar 2016 15:18 #163291
by gilburton
Replied by gilburton on topic LOWERING a Jimny?
If he wants to drive at 90mph might be easier to get a car lol
Isn't top speed on a Jimny 87mph??
I get nervous at anything over 70 on a straight rd lol
03 Mar 2016 17:39 #163301
by facade
Replied by facade on topic LOWERING a Jimny?
In The Olden Days we used to warm the spring coil in the middle with a torch and collapse it :whistle: .
Worked fine on the billiard table smooth roads we used to have back then.
I'd imagine the first bump would dislocate the spring nowadays. :laugh:
Also in The Olden Days there used to be lots of these places called "factories" that made stuff, rather than just warehouses and shops like now, and you could get your tired springs reset, or a set of custom springs made that would lower the car properly for reasonable money. I don't know if such "factories" exist now, I haven't seen one for years, as they all seem to be housing developments.
03 Mar 2016 19:00 #163306
by Busta
Replied by Busta on topic LOWERING a Jimny?
Put rear springs in the front and chop a coil off another set of rear springs for the rear. This will also give a slightly higher spring rate in the rear.
Time to create page: 0.101 seconds
