Ignition Failure. Any Ideas please !
25 Feb 2016 12:07 #162980 by Grasshopper
Hi All.
I am experiencing total engine failure after a normal cold start, runs fine (for 10 - 20 mins) then suddenly cuts out. There is no cutting in & out, just a clean stop. Coming back later she starts again normally. I am thinking its a temperature related issue but where to look ?
Its the 1328 cc DOHC engine
There is no spark at the plugs but there is power at both coils, have replaced both crankshaft & cam shaft sensors still same problem.
Anybody experience the same or any ideas would be much appreciated.
Dave
The only benefit of age is experience.
25 Feb 2016 20:08 #163004 by kirkynut
This has me scratching my head.
I'll keep scratching it and see what happens!
The following user(s) said Thank You: Grasshopper
25 Feb 2016 21:59 #163009 by skywalker65
For there to be power to the coils but no spark suggests either ignition coils packing in when they get hot( I suffered this back end of last year but it dropped on to 2 rather than cut out) ran perfect when it was cold
No fault codes by the way
Or a fault on the triggering side and I would imagine the engine Ecu will switch the coils on/off from the information by the crank sensor.
Tbh my moniey is on the coils
Got some NGK ones off eBay and it's been fine ever since
If in doubt ...... Flat out ??
26 Feb 2016 09:25 #163015 by Grasshopper
Thanks for your initial thoughts guys.
The problem I have with skywalker65's idea is that I can't see both coils failing at exactly the same time or recovering at the same time. The engine does not drop down to two cyclinders, it just stops as though you have switched off.
But who knows stranger things have happened. At the moment its doing my head in !
27 Feb 2016 13:48 #163044 by kirkynut
Grasshopper wrote: Thanks for your initial thoughts guys.
My thoughts too. Does the immobiliser padlock light come on the dash when it dies. It should go off when you turn the ignition on.
27 Feb 2016 20:22 - 28 Feb 2016 07:31 #163061 by skywalker65
It would be possible re the coils. Given where they live stick type coils are notorious for breaking due to the extreme heat .
Mine started out as a hiccup and just got worse
Totally fine from cold and then started to miss. Difficult to pin point an exact timescale as it could vary.
Did you use a genuine crank sensor ?
Can be all sorts of issues with pattern ones. See if you can trace the crank sensor wiring back to the Ecu and check for continuity. Same for the coil trigger wires.
When it cuts out are all the dash lights still on. Total electrical failure might be battery related
When it does cut dead can you read out any fault codes?
Last edit: 28 Feb 2016 07:31 by skywalker65.
Time to create page: 0.107 seconds
