T-Max OUTBACK 12V 9000 lbs Winch problems
- atnas666
Mine after 4 uses has stopped working..
Was winching at the time, stopped winch to check security, Then tried to carry on but nothing just click from the solenoid pack.
Any ideas?
Is there a way i can test to see if its motor or solenoid (its just over a month old)
Thanks in advance
- wombat
- atnas666
wombat wrote: Get back to the suppliers, will still be under warranty
I will just wanted to know if there was a way to test it.
The other reason is coz i dont want the supplier thinking im mucking him about (jimnybits) As had a problem with his winch tray too and this was from the same order(resolved and very helpful)
- atnas666
- TomDK
atnas666 wrote: Hi guys has any one had experience with these?
Any ideas?
Thanks in advance
You can try something out yourself.
Put a positive lead directly on the A and either of the F terminals on the winch motor itself. And of course a negative lead on the Ground terminal. That way you can see if the winch motor still works or if it's just the solenoid.
