Split charger
  • Dave cc
10 years 9 months ago #162567 by Dave cc
Split charger was created by Dave cc
Looking for someone who's is cleverer than me been offered this split charger but not sure if it will do the job on a Jimny thoughts please its a sure power 1602
www.cooperindustries.com/content/public/...rands.surepower.html
  • OllieNZ
10 years 9 months ago #162579 by OllieNZ
Replied by OllieNZ on topic Re:Split charger
Should do the trick. Freebie?
10 years 9 months ago #162580 by facade
Replied by facade on topic Split charger
They are used in boats quite a lot.
What they are is a pair of high current Schottky diodes connected back to back.
You remove the alternator output lead from the battery positive and connect to the centre tap of the two diodes.
One battery goes to each diode,
Both batteries charge, but cannot discharge to each other.
The disadvantage is there is slightly less voltage at the battery (even a schottky diode has a voltage drop), so usually, the alternator is converted to remote sensing, and sensed off the starter battery, although you could just add a diode in the sense wire and bump the regulated voltage up by a diode drop.
Fitted one to my brothers barge once, it is the right way to go, but isn't as simple to fit as they say, as you have to modify the alternator to be externally sensed.
Some denso alternators have an S terminal, that connects straight to the battery with a thin wire, these are externally sensed, and work perfectly in this arrangement, but I don't think the jimny one is this type.
  • Dave cc
10 years 9 months ago #162583 by Dave cc
Replied by Dave cc on topic Split charger
Nice one guys thankyou just found this good guide facade you were spot on
www.12voltplanet.co.uk/split-charging.html
Time to create page: 0.079 seconds
