Warning light
  • mark_w
10 years 9 months ago #162418 by mark_w
Warning light was created by mark_w
Hi guys,
A while ago, my warning light started coming on, but only when I turned left then would go off again when I straightened up. It now seems to have got worse. It now stays on except for when I take a big right turn, but then comes back on when I straighten up. If the trend continues, I imagine it will just be on all the time pretty soon.
Does anyone know what can cause this? The handbrake is definitely fully disengaged and I've checked the brake fluid.
It may also be worth mentioning that on a couple of occasions quite a while ago. The car has not budged when I release the handbrake.
I park on a hill so usually I just put it in neutral, take off the handbrake and roll back, but as I say, there's been a handful of times when the car has just been stuck in place and I've had to put it in reverse and give the accelerator a good nudge just to get the jimny unstuck.
10 years 9 months ago #162422 by facade
Replied by facade on topic Warning light
I assume you mean the Eye of Sauron symbol?
As you say it indicates handbrake on, or low fluid.
However, a few people have reported that a faulty ignition switch can cause this (I can't see why though) and wiggling the key can put it back out.
The brake sticking on will be the shoes rusting to the drums, only solution is to whip the drums off, and clean everything, then let them dry out before replacing. Probably someone has driven through deep water, or mud and it is inside the drums.
Time to create page: 0.061 seconds
