arb locker
- rexthecat
13 Feb 2016 19:46 #162335
by rexthecat
arb locker was created by rexthecat
Just had ARB locker put in the back, seems to engage OK BUT seem to have a problem in that the compressor won't switch off, just keeps going. There also an ARB in the front and was put in about a year ago.
Does that sound like the wirings wrong?
Cheers
Cheers
- rexthecat
13 Feb 2016 21:22 #162343
by rexthecat
Replied by rexthecat on topic arb locker
Yeah I was thinking pressure switch, we checked for leaks and couldn't find any. The bloke who was fitting it was swapping the plugs over at the compressor so switch 1 became switch 2 if you follow. I got bit confused by the way should work, maybe best to start again with the switches and solenoids. Is the pressure switch just the bit that screws between line and compressor? I didn't look proper at that end.
Cheers
Cheers
13 Feb 2016 21:56 #162345
by Keithy
Replied by Keithy on topic arb locker
If you follow the arb instructions the rear locker has to be energised before the front can be energised.
Is it holding pressure when the lockers are engaged?
It should hold pressure for 10 minutes+
- rexthecat
14 Feb 2016 17:08 #162375
by rexthecat
Cheers folks, got it sorted, was just plumed in wrong ways round, swapped the plugs and lines round and all seems to work a treat. Compressor charges, rear locker engages and then front, compressor switches off. Proper relief as their not cheap eh?!
- TomDK
14 Feb 2016 18:09 #162381
by TomDK
Depends where you got the locker from. Hope you didn't pay full Jimnybits price
Replied by TomDK on topic arb locker
rexthecat wrote: Cheers folks, got it sorted, was just plumed in wrong ways round, swapped the plugs and lines round and all seems to work a treat. Compressor charges, rear locker engages and then front, compressor switches off. Proper relief as their not cheap eh?!
- wombat
14 Feb 2016 18:38 #162391
by wombat
Replied by wombat on topic arb locker
Come on Tom, watching this with interest
So where would you recommend getting them in the UK cheap for a jimny Tom??[/quote]
Time to create page: 0.099 seconds
