arb locker
  • rexthecat
10 years 9 months ago #162335 by rexthecat
arb locker was created by rexthecat
Just had ARB locker put in the back, seems to engage OK BUT seem to have a problem in that the compressor won't switch off, just keeps going. There also an ARB in the front and was put in about a year ago.
Does that sound like the wirings wrong?
Cheers
  • rexthecat
10 years 9 months ago #162343 by rexthecat
Replied by rexthecat on topic arb locker
Yeah I was thinking pressure switch, we checked for leaks and couldn't find any. The bloke who was fitting it was swapping the plugs over at the compressor so switch 1 became switch 2 if you follow. I got bit confused by the way should work, maybe best to start again with the switches and solenoids. Is the pressure switch just the bit that screws between line and compressor? I didn't look proper at that end.
Cheers
10 years 9 months ago #162345 by Keithy
Replied by Keithy on topic arb locker
If you follow the arb instructions the rear locker has to be energised before the front can be energised.
Is it holding pressure when the lockers are engaged?
It should hold pressure for 10 minutes+
  • rexthecat
10 years 9 months ago #162375 by rexthecat
Cheers folks, got it sorted, was just plumed in wrong ways round, swapped the plugs and lines round and all seems to work a treat. Compressor charges, rear locker engages and then front, compressor switches off. Proper relief as their not cheap eh?!
  • TomDK
10 years 9 months ago #162381 by TomDK
Replied by TomDK on topic arb locker
rexthecat wrote: Cheers folks, got it sorted, was just plumed in wrong ways round, swapped the plugs and lines round and all seems to work a treat. Compressor charges, rear locker engages and then front, compressor switches off. Proper relief as their not cheap eh?!
Depends where you got the locker from. Hope you didn't pay full Jimnybits price ;)
  • wombat
10 years 9 months ago #162391 by wombat
Replied by wombat on topic arb locker
Come on Tom, watching this with interest :)
So where would you recommend getting them in the UK cheap for a jimny Tom??[/quote]
Time to create page: 0.092 seconds
