4wd Light / Vacuum System Fault
  • CJV8
11 Feb 2016 09:36 #162214 by CJV8
4wd Light / Vacuum System Fault was created by CJV8
Had a fault with the Jimny this morning where the green 4wd light came on when 4wd was selected, but stayed flashing and the front hubs didn't engage.
I know this means there's a fault in the system so shall investigate once the snow stops!
My question was is it normal for the light to remain flashing all the time, even if the car's been shut down and restarted?
Cheers, CJV8.
  • StealthJimny
12 Feb 2016 19:26 #162296 by StealthJimny
Replied by StealthJimny on topic 4wd Light / Vacuum System Fault
what even if you have gone back into 2H?
  • CJV8
12 Feb 2016 22:10 #162304 by CJV8
Replied by CJV8 on topic 4wd Light / Vacuum System Fault
It never came out of 2H.
Ours is the push button version and there was no clunk of the hubs engaging.
  • StealthJimny
13 Feb 2016 01:07 #162305 by StealthJimny
oh you have one of those devil work ones! Um yea if you have selected 4wd and it didn't engage it will flash for as long as it thinks you re trying to have 4wd so it wont stop until you push the 2wd again this is as much as I can help with the push button ones sorry.
20 Feb 2016 21:22 - 22 Feb 2016 09:44 #162728 by auchenblae
I guess it is the two port vacuum valve playing I'm not working today because I can.
What happens.
You push the 4WD button and a signal goes to the 4WD computer.
It sends a signal to the vacuum valve to put vacuum into the activate side of the hubs.
There is a vacuum sensor only on that system not on the deactivate system and if it does not recieve a vacuum after a few seconds of you pushing the 4WD button it sends a signal back to the 4WD computer and it latches to the fault condition.
The only legal way that light goes off is if the vacuum valve starts working again and the vacuum gets to the vacuum sensor.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Last edit: 22 Feb 2016 09:44 by auchenblae.
  • StealthJimny
21 Feb 2016 21:39 #162769 by StealthJimny
crikey! I'm sorry to say but I'm no use then, there is a reason I like levers and cogs lol.
Time to create page: 0.095 seconds
