12v power cable.
11 Feb 2016 05:39 - 11 Feb 2016 05:43 #162209 by HUN
12v power cable. was created by HUN
Hello Guys,
What's the best DIY way to lead a 12v power cable into the cabin from the battery? I'd like to supply permanent power to my dashcam and a small thermo meter - clock combo without touching the bunch of wires located underneath the dashboard.
Thanks for any tips!
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Last edit: 11 Feb 2016 05:43 by HUN.
  • Daniel30
11 Feb 2016 07:21 #162210 by Daniel30
Replied by Daniel30 on topic 12v power cable.
I would spur off the cigarette lighter, or have you got a lot running off it already?
11 Feb 2016 09:04 #162212 by facade
Replied by facade on topic 12v power cable.
Just run a cable from the battery + with an inline fuse holder at the battery end, needs a simple ring terminal at the battery. Then poke it through a suitable grommet or alongside an existing cable then you can neaten it up with some small zipties.
I connected a permanent 12V socket for my solar charger (don't waste your money ;) ) to the live feed at the back of the clock as I was lazy, but the Jimny wiring is a bit marginal on a good day, so I'd go for a separate fused feed, rather than create future problems.
11 Feb 2016 11:04 #162216 by jackonlyjack
Replied by jackonlyjack on topic 12v power cable.
+1 on separate cable
i run 30amp wire in line fuse 20amp
to a terminal behind glove box
then take all need lives from that
with more lower amp fuses
Jack
Time to create page: 0.085 seconds
