aaarrrrgh its done it again
  • streetfighterjeff
10 Feb 2016 08:48 #162153 by streetfighterjeff
aaarrrrgh its done it again was created by streetfighterjeff
the damn car has done its not starting thing again. this time at the petrol station. turn the key and nothing, not turning over or anything. managed to bump it off but now the checkengine ight is on. turned it off on a hill and it started again but still with the light and it started ok when i got home, againe with the check engine light on. anyone know what the immobiliser works on? is it the ignition or the starter? only ask because some bike kill switches will let the engine turn over but not fire( suzuki for example) and some cut all power to the starter motor. this is starting to do my head in now.
jeff
10 Feb 2016 10:32 - 10 Feb 2016 10:33 #162160 by mlines
Replied by mlines on topic aaarrrrgh its done it again
The immobiliser acts on the ignition itself, therefore the engine will turn over and it will appear to "nearly" fire but not actually run.
If its dead then its a more basic electrical problem, such as the starter solenoid or the wiring to the solenoid or the battery connections.
Last edit: 10 Feb 2016 10:33 by mlines.
  • streetfighterjeff
10 Feb 2016 10:55 #162161 by streetfighterjeff
Replied by streetfighterjeff on topic aaarrrrgh its done it again
cheers, found a post about a similar problem, checked the starter as per the post and found the smallspade connector was green, quick clean and she started fine and the engime check light has gone out, hopefully problem solved.
  • jim
10 Feb 2016 22:08 #162201 by jim
Replied by jim on topic aaarrrrgh its done it again
Was going to suggest this. Happened to me the other night.
streetfighterjeff wrote: cheers, found a post about a similar problem, checked the starter as per the post and found the smallspade connector was green, quick clean and she started fine and the engime check light has gone out, hopefully problem solved.
