Not starting help please
- jim
10 years 9 months ago #162114
by jim
Not starting help please was created by jim
After spending a small fortune on the jimny at the weekend it's typical that it decides not to start on a stormy night leaving me stranded. I got in all the lights lit up etc and hadn't been left on but just would start. Battery is fine but nothing from the starter motor.
I managed to get a push from two gents and eventually I got it started and got home. Once in the drive i tried again but to no avail.
Starter motor packed in? Ignition switch?
Thanks
Jim
Thanks
Jim
10 years 9 months ago #162115
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Not starting help please
Try the little spade connection on the starter. Give it a wiggle and try again. If that's it clean it and you should be OK
Grey pick up Jimny
The following user(s) said Thank You: jim
- jim
10 years 9 months ago #162122
by jim
You and the forum are my hero's James.
I gave it a good clean and now starts on the button like it has always done. You should have seen me in my Pjs with a head torch on under the car swearing. The neighbours must think I had a break down :laugh:
Replied by jim on topic Not starting help please
j999pre wrote: Try the little spade connection on the starter. Give it a wiggle and try again. If that's it clean it and you should be OK
Time to create page: 0.080 seconds
