Heater control problem
- Zorbathegeek
10 years 9 months ago - 10 years 9 months ago #162047
by Zorbathegeek
Heater control problem was created by Zorbathegeek
Greetings peeps.
I have an issue with the heater controls on my '03 Jimny.
It started when I couldn't get the screen to de-mist and the heater lever seemed "reluctant" to move to the "screen" position.
Having looked at the plastic linkages alongside the heater up under the drivers footwell, it appears as though the top linkage which diverts the air flow to the screen (1) is not moving fully to the correct position and it seems as though this is due to the large, middle linkage (2), operated by the cable from the heater, not moving fully as it should do.
Jimny heater
by
Andy Jenkins
, on Flickr
It's as if it need pulling forwards with the aid of a spring or something !
Anyone have any ideas ???
Last edit: 10 years 9 months ago by Zorbathegeek. Reason: none
- atnas666
10 years 9 months ago #162053
by atnas666
Replied by atnas666 on topic Heater control problem
i know its not very helpful but mine is broken to
- Zorbathegeek
10 years 9 months ago #162057
by Zorbathegeek
Replied by Zorbathegeek on topic Heater control problem
I feel your pain
10 years 9 months ago #162066
by facade
Replied by facade on topic Heater control problem
The heater control is a simple bowden cable.
At the top, I think the outer just pushes into a socket, and at the bottom, the outer is clamped by a spring clip.
If it isn't moving enough, then either there is something inside the heater (dead Thing, broken fanblade, piece of pollen filter) jamming the flap, or the cable is out of adjustment.
I'd start by flicking the cable inner off the peg on the flap, and see if the flap moves fully, then sort out the cable adjustment by releasing the spring clip and moving the outer, then clamping it again.
The following user(s) said Thank You: Zorbathegeek
- Zorbathegeek
10 years 9 months ago - 10 years 9 months ago #162068
by Zorbathegeek
Cheers for that facade. The flap (2) appears to be free, it just doesn't seem to move the full length of it's travel.
I'll try sorting the cable out.
Do you know if there's a way I can get to the inside of the heater control panel ?
10 years 9 months ago #162071
by facade
From the manual
If yours is a facelift model with turney knobs :blink: I expect it is a similar idea, dismantle the dash and some screws will appear.
Time to create page: 0.113 seconds
