PS/Alternator Belt Replacement
  • Venter
06 Feb 2016 20:35 #162006 by Venter
PS/Alternator Belt Replacement was created by Venter
One of these belts (not sure which one) ate itself today, so now the Jimny is parked outside the nearest garage we could tow it to. I'll speak to the garage 1st thing Monday morning about getting the replacement done.
Anything I should know when I do this? Is it usually only the belt that goes, or do the pulleys often seize at the same time, leading to the belt going?
There was major squealing for a month or more before it went, but I thought it was clutch release bearing so didn't bother seeing to it.
I'm tempted to get the car towed back home to do the work myself (not a mechanical novice, but not an expert either). Would anyone recommend this, or should I just fork out the cash at the garage? If the latter, what sort of price am I looking at?
07 Feb 2016 01:34 #162018 by facade
If it is just the belt, probably about £75 (new belt & an hours labour)
If it is actually the crankshaft pulley, more likely on an M13 engine, could be £400-£500.
The pulley went on mine, and cost about £160 in parts (pulley, bolt, oilseal, both belts) and quite a bit of trouble to change, but is do-able at home in a morning if you follow my instructions on page 2 & 3 of my thread
www.bigjimny.com/forum?view=topic&catid=7&id=59489 for the whole thread.
Belts are about £8 each for Conti cheapos, and they would change in an hour if the alternator lower pivot comes undone easily.
The following user(s) said Thank You: Venter
  • Venter
07 Feb 2016 09:46 #162027 by Venter
Replied by Venter on topic PS/Alternator Belt Replacement
Thanks Facade, some good info in your other thread.
How will I know if it's the pulley that's gone? Is there damage to the pulley that is easily visible?
I'm obviously hoping that it's just the belts, as I don't think they have been changed yet, and the car has 90k on the clock already.
07 Feb 2016 10:49 #162035 by facade
If you look down at the bottom pulley, it will be obvious if the pulley has gone as the outside will have fallen off, and likely is wedged between the radiator and the bottom of the engine.
Changing both belts with cheap parts will cost under £20 and take you less than an hour.
A garage will do it in 20 minutes, but charge you £30 for a genuine belt.
  • mickt
07 Feb 2016 19:07 #162075 by mickt
Replied by mickt on topic PS/Alternator Belt Replacement
The pulley can cause problems on the m13 and it does not necessarily look too bad as did the daughters. Just slight cracking to the rubber is indidicitive to the problem escalating. The daughters ate two alt belts before I bit the bullet and bought a new pulley. Don't forget to ensure all the pulleys grooves are clear of all old rubber and rust before fitting new belts of the correct length for model as the m13 are different to the g13bb.
20 Feb 2016 21:40 #162730 by auchenblae
Well guys I have a two post lift and had to change both belts on my VVT 2007 car and it took me two hours as you have to take out the radiator.
Then changed the alternator this week as changing the belt did not stop the dry bearing at the back of the alternator and had to remove the radiator again.
I cannot work out why Suzuki use that daft 8mm allen key bolt there what is wrong with the normal 12mm AF bolt heads they use on the other pivot and on the adjuster.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.086 seconds
