second gear noise
31 Jan 2016 16:51 #161551
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
second gear noise was created by Mike G
Hi all,
Sometimes when changing into second gear, I hear the gears have a little crunch. It doesn't do it every time and feels like the synchro-mesh is not working correctly. It only happens when changing into 2nd gear, but sometimes I can pop it in without hearing the noise slowly, sometimes I don't need to make any effort and change as normal.
Just wondered if this is something that others might have experienced with M13 gearboxes. Is it a known fault or a symptom that's worth fixing now and avoiding an expensive job later on? I've never taken a gearbox apart and don't think I should start now. If something needed done, I think it would have to be a professional job.
Many thanks
Many thanks
- saboor73
31 Jan 2016 18:43 #161561
by saboor73
Replied by saboor73 on topic second gear noise
Did you ever add friction reducer in transmission ?
31 Jan 2016 18:50 #161562
by Mike G
Replied by Mike G on topic second gear noise
I've never added any additives of any kind apart from standard oils.
- saboor73
31 Jan 2016 19:30 - 31 Jan 2016 19:32 #161563
by saboor73
Any resistance in gear stick when sound occur ? If there is resistance then When was the last time you changed clutch fluid? it expire with in one year and lost is hydraulic punch ability which could make clutch disengaged a bit rough
Last edit: 31 Jan 2016 19:32 by saboor73.
31 Jan 2016 20:08 #161566
by Mike G
nope. The gear stick operates fine. I have a manual version, so I don't think any clutch fluid would be required. I do believe the gearbox oil is due a change. I will change that and see how it fares.
- mickt
31 Jan 2016 20:34 #161578
by mickt
Replied by mickt on topic second gear noise
Its cable clutch if a manual. It sounds like that gear synchro ring is starting to wear. A oil change with the correct oil might help but a suitable additive could help also. It wont fix the wear but it might help make the changes smoother. Try not to rush the change too.
Time to create page: 0.094 seconds
