CB antenna
  • Jimnyrich_91
30 Jan 2016 14:05 #161495 by Jimnyrich_91
CB antenna was created by Jimnyrich_91
Might be a silly question but which round do the washers go on the mount?
Cheers
02 Feb 2016 00:47 #161688 by Mike G
Replied by Mike G on topic CB antenna
Couldn't tell you without knowing which type of antenna you're using and where you're trying to fit it.
Do you have a pic?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • Jimnyrich_91
02 Feb 2016 14:17 #161709 by Jimnyrich_91
Replied by Jimnyrich_91 on topic CB antenna
Got a springer stinger antenna (1.5m) have mounted it on the roof. Everything seems to be working as it should so I'm presuming I have done it right...
  • 1066Boy
02 Feb 2016 17:28 #161720 by 1066Boy
Replied by 1066Boy on topic CB antenna
Have you checked it with a SWR meter? That will soon tell you. :)
02 Feb 2016 20:33 #161746 by Mike G
Agreed, you'll definitely want to SWR it, otherwise you might end up damaging your CB with reflected power. Also, you will maximise your transmit range once the antenna is tuned.
Time to create page: 0.083 seconds
