Insa tyres
- mike390
10 years 9 months ago #161431
by mike390
Insa tyres was created by mike390
Could anyone tell me which insa tyre is most similar in tread to bf mud terrain, thinking Dakar, not sure about Sahara.
Would anyone recommend either of these, or better just to stick to bf muds?
Thanks
Mike
Thanks
Mike
10 years 9 months ago #161440
by kirkynut
Replied by kirkynut on topic Insa tyres
The Dakar is most like the old BFG MT pattern but the new ones that you have now are completely different.
If you can afford to stick to BFG's, I would do so or go to Kumho KL71's as the next best (and much cheaper) alternative.
Remoulds like Insa Turbo's will come up much bigger, even in the same size, which may cause clearance issues and make it slower.
The noise of the Insa's on the road will also be significantly more.
The following user(s) said Thank You: mike390
10 years 9 months ago #161452
by Busta
Replied by Busta on topic Insa tyres
There's more to a tyre than the tread pattern. The rubber compound, tyre construction and even the size of the tyre will be different. It's best to stick to one type of tyre if you can.
- mike390
10 years 9 months ago #161453
by mike390
Replied by mike390 on topic Insa tyres
Thanks for your replies.
Am looking to go up to 29 or 30 tyres, as have a rocklobster and 2.5 suspension lift, the bf's are brilliant tyres, just trying to look for slightly cheaper options as I mainly use my Jim off road.
- Thank you received: 706
10 years 9 months ago #161454
Replied by jackonlyjack on topic Insa tyres
No eBay APP ID and/or Cert ID defined in Kunena configurationthese are the ones i'm going for next
Jack
Jack
- Gundog
10 years 6 months ago #166880
by Gundog
Replied by Gundog on topic Insa tyres
I put Sahara's on mine, very disappointed as they clog up and don't clear the mud resulting in spinning wheels.
Time to create page: 0.113 seconds
