Reverse sensors
  • Davyo
28 Jan 2016 15:10 #161382 by Davyo
Reverse sensors was created by Davyo
Most of these kits come with 4 sensors,but can they be used with only 2 sensors plugged in.
28 Jan 2016 19:01 #161398 by Lambert
Replied by Lambert on topic Reverse sensors
In a past life I used to install such things and the ones we used were either 2 or 4 sensor but they were different control units for each type. Can't for the life of me remember what brand they were though.
  • Davyo
28 Jan 2016 19:15 #161400 by Davyo
Replied by Davyo on topic Reverse sensors
Cheers mate,
Ive bought a 4 sensor one off the bay but was wondering if ok to use just 2 sensors.Might just wire it up and see.Was just worried as if i put the 4 in the rear bumper the middle 2 would be uner the spare wheel and in the recess where the number plate is.
28 Jan 2016 19:39 #161401 by Lambert
I can't see an issue with putting 2 in the plate recess assuming they are able to be mounted securely and angled to accommodate the blind spot, are they surface mounted or flush mount?
Most of these operate using a cone and triangulation of the intersection points, the more sensors the nearer the overlaps the finer the sensitivity to objects, so if you can, use all 4.
  • Davyo
28 Jan 2016 20:18 #161403 by Davyo
Thanks this is the kit ebay item370963950468 ( only £12 but mates been using one for 3 yrs with no issue, not jimny) .The sensors flush fit into the bumper but i was worried the spare wheel above would up set the sensors in the recess.
28 Jan 2016 20:35 #161407 by Rhinoman
Replied by Rhinoman on topic Reverse sensors
The reversing sensors are designed to give a wide angle in the horizontal plane but a narrow angle in the vertical plane, otherwise the signal would bounce back off the ground all the time - they should be marked 'top'. They are a fairly standard sensor, I have a datasheet somewhere, I'll look it out.
I also replied on the other thread, if you don't fit the extra sensors then you shouldn't have a problem because the controller won't see a return signal on the 'spare' channels, it depends on how it interpolates the data.
Time to create page: 0.137 seconds
