Jumping Jimny
- Taffie
25 Jan 2016 12:26 #161113
by Taffie
Jumping Jimny was created by Taffie
Ok guys I have a T reg Auto Jimny, so one of the v first engine types I assume.
Basically once a month maybe less I could be driving along an rev counter would drop to zero an hear engine go quiet, put your foot harder on acceleration pedal an all back to normal.
Now I had it fully serviced 2 months ago & told them of problem, they found no faults. Now it does it once every week or so, it's just a pure rev counter drop, either brake an re accelerate or just accelerate and its over an done with, any ideas what it could be ? An if an easy sort fix too ?
25 Jan 2016 12:54 #161115
by facade
Replied by facade on topic Jumping Jimny
Rev counter dropping to zero is usually the crankshaft or camshaft position sensor, on the early engine I think there is only a camshaft position sensor. They are a simple unplug, unbolt rebolt & replug fix.
Basically either the ignition is turning off because of a fractured wire/dirty connection (unlikely) or the ecu thinks the engine has stopped going round- camshaft sensor fault.
- Taffie
25 Jan 2016 12:56 #161116
by Taffie
Replied by Taffie on topic Jumping Jimny
Ok so to start off get my m8 who's a mobile mechanic to pop new sensor on an go from there I guess.
- Taffie
26 Jan 2016 11:52 #161215
by Taffie
Where can I find out for sure if only has a camshaft sensor, as my mechanic has come back to me saying a T reg has both cam & crank sensor and he feels start by changing crank sensor before cam sensor? ??
Time to create page: 0.086 seconds
