Damper Pulley
  • Whaley
24 Jan 2016 14:42 #161063 by Whaley
Damper Pulley was created by Whaley
Hello everyone
where is the best place to get a damper pulley for my jimny M13A engine from been offered a second hand one but not if it's worth fitting a old one again mines been on 13 years assuming it's not been changed before .
  • mickt
24 Jan 2016 17:30 #161078 by mickt
Replied by mickt on topic Damper Pulley
New ones from dealers or they are on the ebay too!
24 Jan 2016 21:34 - 24 Jan 2016 21:35 #161102 by facade
Replied by facade on topic Damper Pulley
Is a damper pulley the crank pulley?
I still can't get mine off, been trying since Thursday :evil:
I certainly wouldn't buy secondhand, unless it was £5, they are pretty marginal anyway, and have a huge design flaw.
The glue must have been better in the Olden Days though, as I reckon mine has been working for 15 years.
Last edit: 24 Jan 2016 21:35 by facade.
  • Whaley
25 Jan 2016 14:17 #161120 by Whaley
Replied by Whaley on topic Damper Pulley
That the one pal I'm going to try and get mine of on Wednesday hope it goes ok will let you know what have you tried ?
  • andyb5187
25 Jan 2016 14:35 #161123 by andyb5187
Replied by andyb5187 on topic Damper Pulley
I got my pulley off ebay, genuine suzuki £125. Straightforward enough to fit, if you're struggling getting the old one off, I used a small ratchet extension bar and inserted it through the pulley and jammed it against the block to stop it turning while I undid the crank bolt. Same for tightening up, cant remember the tightening torque off the top of my head but if I get chance to look through the tech manual later I'll post it up.
I should remember! I only changed it last month! :unsure:
Cheers
Andy
25 Jan 2016 15:47 #161138 by facade
Whaley wrote: That the one pal I'm going to try and get mine of on Wednesday hope it goes ok will let you know what have you tried ?
www.bigjimny.com/forum?view=topic&catid=7&id=59489
Yesterday I borrowed an Ingersol Rand 131-S dual hammer windy gun, which should be good for 610Nm and it doesn't even tickle it.
Martin is getting me a new bolt and the oilseal (that I probably fried with the torch warming it up) and I will have to take the bumper off for access, make a drill guide and drill the head off, and probably drill the bolt out and recut the threads.
In the meantime my brother thinks he can borrow one of those electric guns, if it is one with 1200 ftlb breakaway torque it might shift it, can't hurt to try before I break something, as I doubt if I have a tap for the thread, as it will be a fine thread not ISO.
Time to create page: 0.096 seconds
