Hello and Remote Central Locking
- Mikegardy
I have a list of mods I would like to do but first thing first.
The door key is a bit hit and miss so I have decided to fit remote locking and bought a cheapo kit off ebay.
Mine is a 5 wire central locking and reading some posts says you need to do some wiring in door to make the lock function work.
Can someone elaborate on this instruction and guide me through.
Many thanks in advance.
Mikegardy wrote: Hello all I have just bought a 2000 Jimny Tin Top after owning loads of other 4wd to see what they are like.
I fitted one of those cheapies from eBay to my Jimny and when I did mine using my own solenoid was IMHO the simplest approach. Now several cars later I do things differently if at all possible still using the cheapie ones; I locate the OE central locking relay and find the wire for lock, the wire for unlock and connect to them. I find them (and which is which) using a test probe bulb to earth.
Regarding actual connection I just wire up using the destructions.
What other fourbies have you had??
- Mikegardy
Mikegardy wrote: Yes that's what I thought I can find the unlock wire but the lock wire seems illusive and I have read a post on here that mentions something about bringing another earth wire from lock
So it may be more expedient to fit a solenoid in the door.
www.bigjimny.com/forum?view=topic&catid=...default&limitstart=0
- Mikegardy
- Whaley
