Coolant
  • RedSoul
10 years 10 months ago #160266 by RedSoul
Coolant was created by RedSoul
New Jimny owner with another numpty question........checked coolant level and found it to be near on bottom limit so topped up with Granville zerocol red coolant which I had kicking around and didn't think that it had blue/green coolant in it and might be an issue.
So question is will it be ok or does it need to be flushed out.
  • RedSoul
10 years 10 months ago #160275 by RedSoul
Replied by RedSoul on topic Coolant
Cannot check as it is now dark but as I haven't started the engine since top-up would it be an easy job just to take overflow tank off and empty contents without causing an air lock.
  • mickt
10 years 10 months ago #160277 by mickt
Replied by mickt on topic Coolant
Yes to second query about top up tank and I doubt it would make any difference,
  • RedSoul
10 years 10 months ago #160278 by RedSoul
Thanks for the reply...have read a whole load of posts on the net about not mixing red with blue coolant hence my post.....should have looked it up first before pouring in but was in a rush chasing the light.
  • 1066Boy
10 years 10 months ago #160293 by 1066Boy
Replied by 1066Boy on topic Coolant
Do not mix them. :ohmy:
Also on older systems the pink/red long life coolant attacks any soft metal fittings within the
system. Not up to speed on the jimny system but in my old shogun it damaged the heater
matrix. My understanding is that the pink stuff is for modern plastic systems. :sick:
Time to create page: 0.086 seconds
