cylinder head
- Colm1
10 years 10 months ago #160102
by Colm1
cylinder head was created by Colm1
head needed for 1.3 single overhead cam sohc '00 model. the body on the 00 model is excellent
i also have a 02 model with good engine,failed nct, double overhead cam engine, body failed nct on rust, can i change the engine into the older model if so, how complicated? what spec advice?
from Dublin,advice is limited here
10 years 10 months ago #160104
by j999pre
Grey pick up Jimny
Replied by j999pre on topic cylinder head
You would need to swap wiring. Ecu and locks, engine gearbox and manifold's and downpipe
Grey pick up Jimny
10 years 10 months ago #160105
by j999pre
Grey pick up Jimny
Or swap the 00 body on to the 02. You would still need to swap wiring and ecu and locks though
Grey pick up Jimny
- Colm1
10 years 10 months ago #160106
by Colm1
Replied by Colm1 on topic cylinder head
what is involved in swapping the bodies? or the car is only worth 800euro over here, but the body on the '00 is 100% rust free, is it worth it?
we have 3 jimnys,also have an 06 and we paid 2800 for it, the '02 with the bad body is only rust on the boot section and wheel arches,is that worth fixing, i am fitter welder by trade so can do some work myself.
10 years 10 months ago #160107
by facade
Replied by facade on topic cylinder head
Don't know whether you pay the same tax as over here, but the 00 will be a lot cheaper to tax than the 02, so I'd consider swapping the 02 engine, transmission, wiring & ecu and door locks over to the 00, rather than swap the body, as you would still need to swap the wiring ecu and locks anyway.
Time to create page: 0.090 seconds
