Front Wheels Locked!
- Alex
09 Jan 2016 12:12 #160062
by Alex
Front Wheels Locked! was created by Alex
09 Jan 2016 12:17 #160063
Replied by mlines on topic Re:Front Wheels Locked!
Those are fixed hubs, so yes it will be locked. Hope you didn't pay too much for them, sorry for the nrws
Sent from my Nexus 5 using Tapatalk
- Alex
09 Jan 2016 12:25 #160064
by Alex
Replied by Alex on topic Re:Front Wheels Locked!
Will it matter that they are locked or should I try and find manual ones?
09 Jan 2016 12:36 #160065
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:Front Wheels Locked!
I have manual ones but mostly leave them locked so basically just the same as you. No issues other than a bit more fuel use and obviously more wear to front transmission parts. However I tell myself that these parts are better to be rotating regularly rather than not so it's doing some good. My weird logic I guess.
Grey pick up Jimny
09 Jan 2016 16:34 #160076
by facade
If it is in 2wd and one front wheel is jacked up, it should turn with a bit of resistance. If it won't turn at all, (but will rotate a few degrees each way then the transfer is still in 4wd.
If it won't move, the flange is fouling on the hub nut.
Replied by facade on topic Front Wheels Locked!
Alex wrote: Got these hubs from a vitara and some spacers from Jimnybits, just fitted them and my front wheels are completely locked!
Does the 4x4 system not allow the front axle to rotate freely when 2wd is engaged?
10 Jan 2016 00:15 #160100
by kirkynut
Replied by kirkynut on topic Front Wheels Locked!
I run fixed hubs without issue.
What do you mean by locked?
Time to create page: 0.099 seconds
