Manual Hubs
- Langdonm
09 Jan 2016 10:49 #160055
by Langdonm
Manual Hubs was created by Langdonm
09 Jan 2016 11:20 #160057
by facade
Replied by facade on topic Manual Hubs
Most likely, there are some hubs made specifically for an unmodified Jimny though.
You need to look at the inside to tell- specifically how deep the gubbins sit in from the face of the flange.
The vacuum system has a raised lip on the hub nut that runs inside the seal in the vacuum hub. This will foul on the gubbins inside the manual hub, so the spacer moves the manual hub further out.
What you can do, is grind all this raised lip away to give a shorter plain nut that won't foul, then any hub that will fit the bolts and the CV splines will work.
However, if you do that, there can be no going back to vacuum hubs, unless you replace the nuts, and a new car is cheaper than buying them from suzuki :S
The following user(s) said Thank You: Langdonm
- Langdonm
09 Jan 2016 11:36 #160059
by Langdonm
Replied by Langdonm on topic Manual Hubs
So basically I won't know till I try
I thought I read somewhere that if you buy the ones from jimnybits there just a simple exchange !!
- minibbb
09 Jan 2016 11:39 #160060
by minibbb
Replied by minibbb on topic Re:Manual Hubs
If they're the ones from jimnybits then no spacers needed- I have these on mine and the bolt straight on and are spot on
- Langdonm
09 Jan 2016 11:52 #160061
by Langdonm
Replied by Langdonm on topic Re:Manual Hubs
Awesome
Thanks for the advice both
- Langdonm
14 Jan 2016 14:57 #160340
by Langdonm
Are these Hubs supposed to come with bolts ?
The bolts in my existing Hubs don't fit
Time to create page: 0.108 seconds
