engine whine.................
- garry55
10 years 10 months ago #160052
by garry55
engine whine................. was created by garry55
when cold. Off to see a Jimny on Monday which vendor says has a whining from the engine when cold, but then disappears when engine warms up. Had a search through forum but there seems to be several suspects - usually belts - but nothing that I can see that matches the problem afflicting my potential purchase.
Any suggestions as what to look for much appreciated.
- gilburton
10 years 10 months ago - 10 years 10 months ago #160098
by gilburton
Replied by gilburton on topic engine whine.................
Could be a number of things intake related around the air filter eg hoses loose or something not properly connected or possibly the viscous fan??
My fan failed and I have it locked up with cable ties.
It's definately noisier than before.
Descriptions of noises can vary wildly depending on who is hearing it.
It could be belt squeal as usually this time of year you have lights/heater/ demist elements all switched on causing a load on the alternator especially first thing??
All you can do is listen for the noise and try and pinpoint it before it warms up.
Last edit: 10 years 10 months ago by gilburton.
10 years 10 months ago #160099
Replied by mlines on topic Re:engine whine.................
The power steering pump makes quite a whining noise which is common. The bearings in the various pulleys ( power steering, air con, tensioner, alternator) can be noisy.
Sent from my Nexus 5 using Tapatalk
10 years 10 months ago #160128
Replied by helijohn on topic engine whine.................
My first guess would be the alternator (bearings perhaps); lots of vehicles seem to suffer with noisy alternators these days on start up. Each of these elements like fanbelt, power steering pump etc. do tend to make unique noises often fairly identifiable and locatable.
Time to create page: 0.073 seconds
