Simple fix?
- 1066Boy
08 Jan 2016 16:37 #160016
by 1066Boy
Replied by 1066Boy on topic Simple fix?
That can wait until the better weather then.
- mickt
08 Jan 2016 19:25 #160026
by mickt
Replied by mickt on topic Simple fix?
If wired in correctly the front fogs are on when dip beam is selected but should not come on when full beam is selected.
- Thank you received: 2004
10 Jan 2016 09:54 #160101
Replied by Lambert on topic Simple fix?
Mine are factory and they come on with sides, dipped and high beam.
- mickt
10 Jan 2016 18:15 #160113
by mickt
Fondly enough I retro fitted a set to my daughters car following the instruction leaflet that came with the kit from Suzuki. I was expecting the fog lamps to work as per what was/is! UK spec i.e. fog lights not allowed to work when main beam on but lo and behold when I checked they do so I am flummoxed as what the regs are now. Common sense would dictate that having main beam on in fog is wrong as the fog acts as a reflector and you blind yourself hence the fogs are wired to the dip and side only, or were.
- Statey
10 Jan 2016 22:36 #160140
by Statey
Replied by Statey on topic Re:Simple fix?
I've just fixed mine! Try tracing the wire back behind the headlights drivers side and make sure the ground wires and secure and also well connected! That was my issue
Time to create page: 0.129 seconds
