Deeper water than I expected!
- Alex
04 Jan 2016 21:28 - 04 Jan 2016 21:29 #159765
by Alex
Deeper water than I expected! was created by Alex
Hi guys,
I was out laning with some friends and I came across some water that I went through the previous week fine, however it was much deeper this time and it went over my bonnet causing my speed to reduce and nearly stall due to being in high ratio :S
(I have a snorkel of sorts, which takes the air intake further up the engine bay)
The truck seems to be running fine now, but I would like make sure the water has not damaged anything on it.
Can you recommend any checks which I can do, or things to change?
Also on the way home I found that the clutch was quite creaky and a bit stiffer than before the trip, is this to do with the water? and how can I fix it?
Cheers,
Alex
Cheers,
Alex
Last edit: 04 Jan 2016 21:29 by Alex. Reason: .
04 Jan 2016 21:52 #159769
by Busta
Replied by Busta on topic Deeper water than I expected!
If you haven't extended the breathers on the axles and transfer case then you should drop the oils and replace them. You will see if water has got in or not. The swivels are probably full of water but you might as well wait until the kingpin bearings go before stripping them.
Both of these are issues if you go in water over about a foot deep. Otherwise, if she runs fine she is fine.
- Alex
04 Jan 2016 22:02 #159771
by Alex
Replied by Alex on topic Deeper water than I expected!
Thanks Busta,
I have ordered the axle breathers so I will change the oil when I fit them.
Do you have any ideas on the clutch problem?
05 Jan 2016 22:41 #159849
by kirkynut
Replied by kirkynut on topic Deeper water than I expected!
I would drop the axle oils asap and not wait as mayonnaise isn't a very good lubricant of gears. If not drop a little to check the condition of the oil and top up accordingly.
Similarly, I'd consider dropping the lower kingpin on both sides to let any water out and re-packing with waterproof grease. The only thing is that if you've not had the kingpin bearings out before they can be seized in.
In respect of the clutch it could be the cable has been washed of its grease or the release bearing has been washed of its grease and is a bit sticky sliding back and forth on its shaft.
It might free up with use.
I found a new clutch cable made a world of difference and have not had any problems with my clutch after wading.
Sounds like you need a snorkel though!
