Castor correction with std arms and plates?
  • thompo
04 Jan 2016 19:55 - 04 Jan 2016 20:04 #159752 by thompo
I'm sure someone has asked this before but I can't find it.
What are the reasons for correcting with modified arms instead of altering the mounting points? is it for mot?
Only asking as I've just lifted mine 3" (but looks more) and the steering isn't great. Can't stretch to new arms for a month or so but I was thinking of other options and drew up some plates to correct the angle.
Any reasons for not going this way? from my rough drawing I think it will move the axle back slightly correcting like this.
I would have to weld the plates on and if done right I should be able to use both mounting points if I ever want to remove the lift.
thanks
Last edit: 04 Jan 2016 20:04 by thompo.
  • mickt
04 Jan 2016 19:59 #159753 by mickt
Illegal for road use I would say so yes to Mot as non standard as per manufacturers spec and so insurance problem. Ok for off road should be OK
04 Jan 2016 20:36 - 04 Jan 2016 21:05 #159759 by Busta
Looks like a good solution.
Downsides according to your drawings are a slight reduction in clearance under the arms (although most aftermarket ones seem pretty bulky in that area anyway).
I think the reason most people go for camber corrected arms is because they lack fabrication skills to engineer their own solution. And for the fabricators, making and delivering arms is easier than modifying axles. Some say the standard arms are weak. I'm not sure how true that is.
Legally I'm not sure that any of the after-market manufacturers products have any certification or testing for road use? S200KYS will know if ORA do for their arms.
Last edit: 04 Jan 2016 21:05 by Busta.
  • idiotmobil
04 Jan 2016 21:06 #159762 by idiotmobil
Replied by idiotmobil on topic Castor correction with std arms and plates?
What you doing is basically done with correction bushes. Also corrected arms are im sure longer to not just a changed angle. Stick bushes in the front till you can afford arms then stick the bushes in the rear ones to correct them
09 Jan 2016 17:14 #160080 by Rhinoman
I don't see anything wrong with that idea as long as your welding is good, I also see no reason why it would be illegal. If you can get the holes in the right places then you may be able to get away with standard length arms. I think that, for most people, bolt on parts are simpler than trying to get the engineering right and not everybody is confident enough to weld in a critical place like that.
I have seen a few standard arms that have bent.
09 Jan 2016 20:27 #160092 by Keithy
I extended the front eye downward on the front mtg point.
Cost me an hour in time and corrected the steering geometry....perfick!
I'll be 5 linking my rear end once I have a few projects out of the way.
How much clearance on the front prop do folks have with large lifts btw.....mines close to the cross member on extension with a 70mm lift.
Time to create page: 0.144 seconds
