ABS fault diagnosis problem
10 years 10 months ago #159496 by Mike G
Since taking my rear axle off to do some maintenance and modification, I've now refitted it only to find that my ABS light on the dashboard is illuminated constantly. I dug out the technical manual and as I don't have a fancy computer for looking at fault codes, I decided to use a bridging wire on the open connector under the dashboard to find out what the codes were using the ABS light flashing codes. It turns out, as expected that the codes were 32 and 36, which are both rear sensors. I then tried to find out if there were any breaks or shorts in the sensor wires by using a multimeter on the ABS controller electrical harness connector plug, but my results were no good. It indicated that 3 of the sensor wires were 2 mega ohms and over, whilst only one was in range at 1.3 kilo ohms. Upon inspection of the harness connector, I found that some of the pins I wanted to test didn't have a conductor in them, which would explain the large resistances :blush: . I then cross-referred the pin-out on the connector to the diagram and found that they didn't tally up, so now I'm at a dead end as I don't have any documentation to confirm what goes where. Does anyone know if there are diagrams for the different types of engine? Perhaps there are different variants of ABS modules. My engine is M13.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • wombat
10 years 10 months ago #159504 by wombat
Replied by wombat on topic ABS fault diagnosis problem
Hi, assuming there was no problem before you removed the axle, and the fault codes say the problem is with the rear sensors i would check the connectors at the rear that connect the sensors to the vehicle wiring loom :)
10 years 10 months ago #159509 by Mike G
Replied by Mike G on topic ABS fault diagnosis problem
Thanks,
Yes, there was no problem before I started, so it should be something simple.
I started at the clean end as I thought I'd be able to check the wiring all the way through without having to get on the muddy ground. I did think about removing, checking and reseating the sensors in the axle, but opted for the easiest work first.
I'll get it on the ramps tomorrow, have a look at the connections at the rear and use up some contact cleaner on the connectors/sensors.
10 years 10 months ago #160470 by Mike G
Forgot to update.
I found that it was a simple issue of me not being thorough enough when refitting the sensors. I think it was because I didn't want to damage them when refitting, but there was a fingernail size gap between the hall effect sensors and the rear axle, I put a block of wood against them and tapped them in to reduce force impact, checking the distance after a few taps. When I got in the car and drove it about 20 metres, the fault cleared and the ABS light extinguished without the need for me to do any code clearing action.
  • Daniel30
10 years 10 months ago #160471 by Daniel30
Replied by Daniel30 on topic ABS fault diagnosis problem
Happy days glad you got it sorted ;)
10 years 10 months ago - 10 years 10 months ago #160473 by Mike G
Thanks Dan,
It's nice to have things operate as they are supposed to.
Just got to get my A/C problem fixed now and everything is tip top, but that's a different story. Think the clutch assembly is just rusted on the 'engaged' position. I've ordered some rust removal gel, so hopefully with a few applications and overnight waits, it might unseize without removing the unit. Not holding my breath, but it's worth a try.
Last edit: 10 years 10 months ago by Mike G.
Time to create page: 0.103 seconds
