4wd not working
  • Langdonm
30 Dec 2015 21:22 #159374 by Langdonm
4wd not working was created by Langdonm
Got stuck today as my 4wd has stopped working 😭
What's the best way for me to narrow it down to what it could be ?
The propshaft spins fine
Could be simple but I'm new to this
Thanks
  • StealthJimny
30 Dec 2015 22:38 #159378 by StealthJimny
Replied by StealthJimny on topic 4wd not working
Hi bud. I will give you the same advice I got when I had this problem,
"Swap your vacuum hubs for manuals".
Because I love tinkering with things I ignored this at first in favour of finding the problem and fixing it but after an hour of feeling for suction on the ends of the pipes and cleaning the solenoids and looking for cracks in the pipes and getting to the vacuum chamber I realised that I would just have to do it all again the next time the system failed and the next and so on so then bought these.
www.jimnybits.co.uk/shop/jimny/drivetrai...el-hubs/prod_33.html
I now know I don't have to fiddle about with all that tat ever again.
  • minibbb
31 Dec 2015 00:18 #159389 by minibbb
Replied by minibbb on topic Re:4wd not working
Seconded! Fitting manual hubs after my vacuum hub issues has given me massive peace of mind.
I went for the AVM copies from jimnybits which are great
31 Dec 2015 00:52 #159392 by Keithy
Replied by Keithy on topic 4wd not working
Have a look in the info section at the top of the site at the "how to guides" there's one on the vacuum system in there.
If you have vacuum in all the right places consider looking at the seal on the front inner hub....mine only lasted 13 years.
  • Langdonm
31 Dec 2015 18:16 #159436 by Langdonm
Replied by Langdonm on topic 4wd not working
Ok thanks will defiantly do this soon 👍🏻
Only issue is I don't wanna replace them and it don't solve it ( that's my luck )
it says on the description of them hubs that the 4x4 light will be flashing but I've never had that !!
Will have a read through that section now
Cheers
31 Dec 2015 18:25 #159438 by Busta
Replied by Busta on topic 4wd not working
As many of us stick with the vacuum hubs as switch to manual. Check for obvious things like worn wheel bearings (movement in the bearings means the vacuum gets past the seals and can draw in crap.)
Time to create page: 0.098 seconds
