Planning a Jimny build
- Nyzeta
26 Dec 2015 15:51 #159139
by Nyzeta
Planning a Jimny build was created by Nyzeta
Dear readers
I'm new to the forum but I've been lurking around unregistered for a while. First of all thanks for a wonderful collection of knowledge and personalities:)
Second: I'm going to buy myself a Jimny again, but this time it's for fun. I have not bought one yet, so all options are open. This is what I plan to do:
- body lift: 1,5" or 2".
- wider arches to accommodate bigger wheels
- longer spring/dampers: 2" TUV papers
- bigger wheels: been looking at 28,5 to 30" usage is first of all gravel/loose and some transport on asphalt. And in the winter its snow and ice so I guess two sets will be needed.
- I'm thinking of replacing the engine block with a 1,6 or 1,8L one depending on what's available in Norway.
- replacing brakes to stop the extra powered engine
- roof rack
- light bar in front and maybe some work lights on the roof rack
- winch
- lower ratio diffs to handle the bigger wheels
- get the whole thing re-registered by Norwegian government.
Think I need a 2006-recent model.
What is the difference between the models SN413Q,SN413V and the added -2,3,4,5,6,7 (eg: SN413V-4). I'm trying to collect info about part numbers as I need to document the use of the same frame in both the 201Nm diesel and the petrol engine. That way I'm
One step closer to get acceptance for a bigger engine.
Any good input would be appreciated
Regards NZ
- roof rack
- winch
Regards NZ
- TomDK
26 Dec 2015 22:31 - 26 Dec 2015 22:36 #159165
by TomDK
Replied by TomDK on topic Planning a Jimny build
Forget about the 2" body lift. No need for it with your suggested size of tyres. If you really want to do a bodylift, keep it at 10-15 mm just for making it easier to the the underside
If you want the suspension TUV approved, get a Trail Master kit. Better shocks than Old Man Emu in my opinion.
No need to lower the diff ratio. Just get a rocklobster transfer box. Much more usable offroad.
For engine conversion, get an M16a. Fits right on. Just make sure whether it's VVT or non-VVT you need.
Regarding a winch. There really is no better winch for the money than a Goodwinch TDS 9.5c. Can't fault them and easily upgradeable if you want
But perhaps you should just get in contact with Norsk Offroad Teknikk. You may know of them?
Last edit: 26 Dec 2015 22:36 by TomDK.
- Nyzeta
27 Dec 2015 01:28 #159178
by Nyzeta
Replied by Nyzeta on topic Planning a Jimny build
Hi TomDK
Thanks for the feedback. I had the impression that one you would need more than 2" lift to go from 205/70 15", which should end up close to 26", to 30". At least in front where the wheels will rub the insides when you turn the steering wheel.
I've seen a good amount of discussion when it comes to swapping engines. Think the work will be the easy part. Worst will be the arguments/paperwork for the Norwegian government. But thanks for the tip.
I did know of NOT
I did know of NOT
- TomDK
27 Dec 2015 10:13 #159180
by TomDK
If you stick with new tyres (non-recourse) 235/35/15 will do fine on a 2" lift.
27 Dec 2015 15:22 #159200
by kirkynut
Replied by kirkynut on topic Planning a Jimny build
Welcome along and I agree with what Tom said.
I would steer clear of a body lift unless you find you absolutely need it but you can easily get extended bump stops to prevent rubbing now from Bits4vits.
A 1" body lift causes minimal knock on problems so again Tom is on on the money.
Do you have to have a 2" lift or is there a 3" lift out there that's TUV approved. I'm assuming it needs to be TUV approved.
New tyres in 235/75/15 from BFG or Kumho KL71's would be ideal and not so aggressive to continually cause CV joint failure.
There's information to be had on fitting a Rocklobster transfer box to a push button transfer box car that you look for and the man behind the rocklobster, Rockwatt will share it with you. He is on this forum or find him on Facebook under Rockwatt Engineering.
He'll sell you a bomb proof fitting kit and advise on which props you need. I think you can even use your original rear prop these days but I can't remember where you get the bits now.
I look forward to seeing it come together when you get it and start the mods.
Be sure to post it on here!
Time to create page: 0.085 seconds
