Tractor joint?
  • Fozziebeard
15 Dec 2015 07:31 #158550 by Fozziebeard
Tractor joint? was created by Fozziebeard
Morning,
I took the little beast to the dealers for a check over, just inherited it from the company, dealers are saying the tractor joint is leaking fluid? Quote canoe to £400+! How painful is it going to be for me to do it on the drive? I've played with scanners before, but if it's easier to take to an Indy I will. I'm based just east of Nottingham so any recommendations?
Cheers
15 Dec 2015 07:52 #158551 by j999pre
Replied by j999pre on topic Tractor joint?
What is a tractor joint?
Grey pick up Jimny
  • Fozziebeard
15 Dec 2015 07:57 #158552 by Fozziebeard
Replied by Fozziebeard on topic Tractor joint?
The dealers are saying it's the front drive to hub/disc area, I think it's the seal (£19) that's leaking but the strip down costs the money.
15 Dec 2015 08:05 - 15 Dec 2015 08:07 #158553 by j999pre
Just look on this site for kingpin replacement do that and replace the outer seal if needed. Parts : 2 x kingpin bearings and inner seal £30 outer seal ( if needed ) £25. Labour 1.5 hours.
The outer seal doesn't cause the leak the inner one does, the outer is more of a dust/muck seal. £400 sounds ridiculous to me.
Grey pick up Jimny
Last edit: 15 Dec 2015 08:07 by j999pre.
The following user(s) said Thank You: Fozziebeard
15 Dec 2015 08:31 #158554 by Busta
Replied by Busta on topic Tractor joint?
As above. It's quite an easy diy job. Unless they are familiar with Jimmy's, they are probably assuming it's the same as a landy and needs a new swivel kit which are much harder to do than the Jimny kingpins. And tell your garage it's called a swivel, not a tractor joint!
  • Daniel30
15 Dec 2015 09:02 #158555 by Daniel30
Replied by Daniel30 on topic Tractor joint?
I would try another garage :)
