Tractor joint?
- Fozziebeard
10 years 11 months ago #158550
by Fozziebeard
Tractor joint? was created by Fozziebeard
Morning,
I took the little beast to the dealers for a check over, just inherited it from the company, dealers are saying the tractor joint is leaking fluid? Quote canoe to £400+! How painful is it going to be for me to do it on the drive? I've played with scanners before, but if it's easier to take to an Indy I will. I'm based just east of Nottingham so any recommendations?
Cheers
Cheers
10 years 11 months ago #158551
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Tractor joint?
What is a tractor joint?
Grey pick up Jimny
- Fozziebeard
10 years 11 months ago #158552
by Fozziebeard
Replied by Fozziebeard on topic Tractor joint?
The dealers are saying it's the front drive to hub/disc area, I think it's the seal (£19) that's leaking but the strip down costs the money.
10 years 11 months ago - 10 years 11 months ago #158553
by j999pre
Grey pick up Jimny
Just look on this site for kingpin replacement do that and replace the outer seal if needed. Parts : 2 x kingpin bearings and inner seal £30 outer seal ( if needed ) £25. Labour 1.5 hours.
The outer seal doesn't cause the leak the inner one does, the outer is more of a dust/muck seal. £400 sounds ridiculous to me.
Grey pick up Jimny
Last edit: 10 years 11 months ago by j999pre.
The following user(s) said Thank You: Fozziebeard
10 years 11 months ago #158554
by Busta
Replied by Busta on topic Tractor joint?
As above. It's quite an easy diy job. Unless they are familiar with Jimmy's, they are probably assuming it's the same as a landy and needs a new swivel kit which are much harder to do than the Jimny kingpins. And tell your garage it's called a swivel, not a tractor joint!
10 years 11 months ago #158555
Replied by Daniel30 on topic Tractor joint?
I would try another garage
Time to create page: 0.096 seconds
