Front calliper slides.
  • Marki
12 Dec 2015 12:48 #158339 by Marki
Front calliper slides. was created by Marki
My Jimny has got a sticking caliper on the front right that I want to take a look at. This will be my first time working on it so I'm have some good honest newbie advice. The first question is where do I jack it up from? It's fitted with a 3" lift kit if that makes any difference? Is there anything that I need to be aware of when it comes to removing the wheel and calliper or is it all straight forward?
Just my own thoughts but since it is only on one side I'm assuming that I can rule out the master cylinder? I suspect that either the slides or the piston are sticking. If it is the slides then is there any suggestions on getting them up and running while I wait for new parts?
Cheers for any advice, it's appreciated.
  • Jayj92
12 Dec 2015 13:16 #158340 by Jayj92
Replied by Jayj92 on topic Front calliper slides.
It's all straight forward mate remove the slider blots check rubbers for wear clean them all up regresse them also clean up the slider plates and grease them if your sliders and rubbers are past there days you can order decent kits of eBay
12 Dec 2015 13:54 #158341 by Busta
Replied by Busta on topic Front calliper slides.
Jack up under the radius arm where it attaches to the axle but anywhere on the axle, radius arms or chassis is tough enough. The wheel change jack fits onto a small lump on the radius arm, but use a proper trolley or bottle jack when working on the vehicle.
Braking issues that look like they could be a faulty master cylinder are nearly always down to seized sliders or worn wheel bearings.
12 Dec 2015 15:23 - 12 Dec 2015 15:24 #158349 by mlines
Replied by mlines on topic Front calliper slides.
When you check the sliders, check the rubbers. These expand if someone has previously used an oil based grease or lubricant on the slider and the slider jams as the boot is too big. Its quite a common problem, people only check the rubbers for splits and do not realise they have expanded.
Here you can see the swollen boots on the left
Last edit: 12 Dec 2015 15:24 by mlines.
  • Gerula
12 Dec 2015 18:06 #158355 by Gerula
Replied by Gerula on topic Front calliper slides.
One thing that should always be mentioned when it comes to this job is the importance of using the proper grease for it. It has to be high temperature silicone grease, rated some 600 degrees Celsius. I'm using this product www.amazon.com/ATE-700015-Plastilube-Lubricant-75/dp/B003VXPY2M but there are many similar ones.
If you use something with a lower flow temperature it will just pour out, while some products may actually dry out due to the hightemperature and seize the sliders really bad.
12 Dec 2015 23:15 - 12 Dec 2015 23:17 #158390 by kirkynut
Replied by kirkynut on topic Front calliper slides.
No eBay APP ID and/or Cert ID defined in Kunena configurationThat Ate grease is expensive. This will suffice and you get enough for life!
It goes up to high enough temperatures look:
www.redrubbergrease.com/
Last edit: 12 Dec 2015 23:17 by kirkynut.
Time to create page: 0.123 seconds
