How robust and durable are radiators
- Thank you received: 2004
10 Dec 2015 05:27 #158212
How robust and durable are radiators was created by Lambert
Car had its mot yesterday all passed all good except they noticed that the rad has a little bit of a leak around the top header joint to the core.
How regular an occurrence is this sort of failure and is it indicative of deeper problems? I would say it might have used half of the expansion bottle possibly but I was not monitoring it so have no idea how long it has taken to get that far though I will now be watching it like a hawk. The car doesn't overheat and for all the test center said they could smell the coolant I haven't noticed it when driving and neither have any of my passengers. All of which suggests that it is a quite recent development.
Because of where it is leaking I doubt that kseal etc will work as it is between plastic and aluminium and even if it might I'm not putting anything like that into the system as it will do as much damage as it does good, maybe on a 15 year old one that I intended to drive into the ground but definitely not a 5 year old one that I want to rely on for a long time yet.
I have been on to the dealer and they want 377 plus tax for a new one, eurocarparts want 52 plus tax which gives me the fear that either the quality is not there or the fitment is miles away. A local factors want 85 plus for a known branded one, denso I think or nissens.
Anyway the upshot of all this is should I be expected to be changing the radiator on a 5 year old car as a semi service item because I kinda thought production technology of such things had reached a point where they were a bit more durable, hell the rad in the defender lasted 18 years and even then it wasn't actually leaking just bunged up and fin-less.
Any views welcomed.
Any views welcomed.
10 Dec 2015 06:37 #158213
Replied by Lambert on topic How robust and durable are radiators
Also as an aside it looking like the rad is coming out I may as well replace the drive belts as it seems to be easier with the rad removed what size do I need for an m13a with factory air conditioning?
10 Dec 2015 07:02 #158215
by j999pre
Grey pick up Jimny
Replied by j999pre on topic How robust and durable are radiators
I got my rad off ebay £46. It fit perfectly and has been on a couple of years without issue.
Grey pick up Jimny
10 Dec 2015 07:06 #158216
That's interesting, I have usually been a bit dubious of cheap parts, maybe wrongly? I will have a look on ebay. Cheers.
10 Dec 2015 07:11 #158217
by kirkynut
Replied by kirkynut on topic How robust and durable are radiators
Both Denso and Nissens are OE rad manufacturers so they will be better than the crap Eurocarparts pump out.
Nissens have a good reputation.
A mechanic I use had a Suzuki Swift just out of its 3 year warranty with a split rad a year or so ago so I think it is just the quality of rads used by Suzuki in that period.
I agree that K Seal will just cause more problems than it will solve. There are many who swear by it but as many that swear at it.
I'd go for the motor factor one. They'll tell you what belts you need from their data book and supply them too. Or look in the BigJimny shop.
I'd offer to look at mine but I'll forget and don't have air conditioning.
10 Dec 2015 07:56 #158219
by Busta
Replied by Busta on topic How robust and durable are radiators
It sounds quite early for a radiator failure but it's unlikely to be a sign of other problems unless you've noticed other symptoms of head gasket failure like white smoke when warm or water in the oil. You could start up the car from cold with the radiator cap off and see if you are getting lots of bubbling through the rad (compression leaking past the headgasket into the coolant) just to be sure.
£85 for a branded one from the motorfactors sounds a good middle ground, although I've not had problems with the cheapest eBay ones either. You'd be wise to avoid K-seal and the like. They are just a bodge.
Time to create page: 0.098 seconds
