High tickover
- Major mallock
10 years 11 months ago - 10 years 11 months ago #158078
by Major mallock
High tickover was created by Major mallock
Hi, new to jimny,s please help. My Jimny has a high tickover, just above 2000 revs. Its not the accelerator cable or the throttle stop. Looked for air leaks etc and drawn a blank, any ideas. Its a 2000 year car, 16v 1300
Many thanks
Many thanks
Last edit: 10 years 11 months ago by Major mallock. Reason: Forgot something
10 years 11 months ago #158085
by kirkynut
Replied by kirkynut on topic High tickover
There's a temperature sensor for the air going in inside the air box that could read cold and the coolant temperature sensor that could read cold, therefore making the ecu think it needs the cold start settings all the time.
I would have checked what you have to be honest thinking the same as you and the above is all I can think of after.
10 years 11 months ago #158088
by j999pre
Grey pick up Jimny
Replied by j999pre on topic High tickover
Idle control valve stuck?
Grey pick up Jimny
- irishguy123
10 years 11 months ago #158092
by irishguy123
Replied by irishguy123 on topic High tickover
Has it been sitting for a long time? Mines did this after it had been sitting for a month or so, as j999pre said it was the Idle control valve stuck open, a few taps with a screw driver handle and it returned to normal
- Major mallock
10 years 11 months ago #158453
by Major mallock
Replied by Major mallock on topic High tickover
Thanks to all,it has been sitting some time. I stripped the idle air control valve and replaced it. I think its worked but I guess I probably need anew one
Time to create page: 0.157 seconds
