high level brake light failed
- littletriple
06 Dec 2015 13:22 #157978
by littletriple
high level brake light failed was created by littletriple
Hi all,
had a look around but couldnt find anything on this. My high level brake light has stopped working. It isnt the bulb so I removed the lining from the rear door & the wiring seems ok in there. So is the high level light simply connected to the others somewhere? Is there a common cause of this problem?
All advice welcome.
cheers, Martin.
All advice welcome.
cheers, Martin.
06 Dec 2015 13:56 #157979
by facade
Replied by facade on topic high level brake light failed
The wiring diagrams simply show it connected in parallel with the left brakelight.
I wouldn't worry, as it isn't tested at the MOT, and it only irritates the driver behind in a traffic queue
06 Dec 2015 14:10 #157980
Replied by Daniel30 on topic high level brake light failed
Have you checked for corrosion in the socket?
06 Dec 2015 14:21 #157981
by facade
I re-read the original post, and if the wire breaks, it will be where it flexes on entering the door, not in the middle of the panel. Sometimes just the copper core breaks, and the plastic looks ok.
- littletriple
07 Dec 2015 08:27 #158015
by littletriple
Replied by littletriple on topic high level brake light failed
thanks all. If it spurs off the N/S brake light it shouldn't be too hard to find the fault...
Have to wait for some daylight first!
- littletriple
01 Aug 2018 19:46 #194769
by littletriple
Hi, finally bothered to find/fix this problem so I thought I should close this out.
There was a broken ground wire (the brake light has its own) in the flexible section between the door & the car - as suggested above. Simply soldered it together & protected with heatshrink. The cables feel a bit hard so may be an age thing..
Time to create page: 0.113 seconds
