Fan belt squeal and broken belts
  • Electric Bloke
05 Dec 2015 17:49 #157924 by Electric Bloke
Replied by Electric Bloke on topic Re:Fan belt squeal and broken belts
It's got a new alternator fitted less than 100 miles ago, and the previous owner was 78yo, he just used it to drive to his allotment, so the alternator should be good!?
  • Electric Bloke
05 Dec 2015 17:54 #157926 by Electric Bloke
Replied by Electric Bloke on topic Fan belt squeal and broken belts
Yes, it's the double overhead cam engine. The belt chirps before it squeaks, and I read that it does that when the pulleys are misaligned, i wondered if the new alternator had caused the pulley to be out of alignment? But it could be the crank pulley?
  • mickt
05 Dec 2015 18:20 #157927 by mickt
Replied by mickt on topic Fan belt squeal and broken belts
I would go for the pulley I paid £171-97 off the main dealer for the pulley and the crankshaft bolt. I got the bolt as it is very tight and anticipated it might get damaged. As it was it came off with my cordless impact driver, which had a fully charged battery to ensure maximum force. Another reason to remove the rad is for access to that bolt. You can get them off the ebay but they worked out more than the dealer!! The bolt was £9.50! Another point is to ensure all signs of old belt is removed from water pump and alternator pulleys using wire brush and sharp pointed tool. The pulley might need easing off with a couple of bolts if tight on shaft.
  • Electric Bloke
05 Dec 2015 18:50 #157929 by Electric Bloke
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks for the info, mickt. I think I'll buy the pulley after listening to what you are saying, this is the one I saw at £124, I think my fan belt code ends in 850.
  • mickt
06 Dec 2015 20:15 #157995 by mickt
4pk 830 for the alt 4pk 850 for the steering pump.
  • Electric Bloke
07 Dec 2015 21:41 #158077 by Electric Bloke
Thanks, mickt, I think I just ordered the wrong belt if that info is correct :( I ordered a Gates 4pk850 for the alternator
Time to create page: 0.162 seconds
