Fan belt squeal and broken belts
- mickt
08 Dec 2015 19:08 #158128
by mickt
Replied by mickt on topic Fan belt squeal and broken belts
As you have to disturb that to do the other and pulley it would make sense to fit it and keep the old one as a spare. It will fit on the alternator and there will be sufficient adjustment for it to function but the makers recommend a tolerance of 5mm max on the recommended "correct length". The figures are the length in mm's.
- Electric Bloke
09 Dec 2015 05:25 #158154
by Electric Bloke
Replied by Electric Bloke on topic Fan belt squeal and broken belts
I thought I'd do that. all parts are ordered now.
Thanks for your help.
- Electric Bloke
11 Dec 2015 16:32 #158309
by Electric Bloke
mickt. My fan belt that's squeaking is a 4pk836. The adjustment is at around half way down the slot on the alternator, is that the wrong belt? My Jimny is a UK 2003 jlx ma13, non air-con.
Thanks.
Thanks.
- mickt
11 Dec 2015 19:39 - 11 Dec 2015 19:40 #158314
by mickt
As I said it should be OK as the factor I spoke to said that within 5mm is recommended so that is as good as a 830.
Last edit: 11 Dec 2015 19:40 by mickt. Reason: amendment to the text
- Electric Bloke
12 Dec 2015 01:47 #158329
by Electric Bloke
Thanks
- Electric Bloke
29 Dec 2015 20:37 #159314
by Electric Bloke
Just a quick update.
I fitted the new crank pulley, and now it runs perfect!
I checked out the old pulley, and you could see that the rubber was cracked and perished. I also ended up fitting a 4pk833 Gates fan belt.
Thanks for your help everyone, especially mickt
