Wheel question
- Mick C
14 Nov 2010 10:59 - 14 Nov 2010 11:00 #5918
by Mick C
Wheel question was created by Mick C
Is it generally the case that the mounting hole part of an alloy wheel is thicker than on a steel rim? ie do you get more stud protruding through on a steely?
thanks in advance!
Mick
thanks in advance!
Mick
Last edit: 14 Nov 2010 11:00 by Mick C.
14 Nov 2010 11:41 #5919
Replied by mlines on topic Re: Wheel question
In short - yes.
There are different wheel studs to compensate for this.
Attachment diskkitaddons6.JPG not found
- Mick C
14 Nov 2010 12:07 #5921
by Mick C
Replied by Mick C on topic Re: Wheel question
Thanks Martin! I guess it follows that a Jimny with alloys on from the factory will have longer studs then.
Cheers
Mick
Cheers
Mick
- ooky_123
14 Nov 2010 16:26 #5925
by ooky_123
Replied by ooky_123 on topic Re: Wheel question
I bought a set of High Tensile studs from my local dealer for about £2 each. I told the dealer they were for larger offset alloy wheels and they were fine.
Dont be tempted to go for cheaper ones for trailers .. you donot want to sheer a wheel stud half way up a green lane !!!..
Time to create page: 0.176 seconds
